Go Back   Pacific Northwest Four Wheel Drive Association > Tool Bag > Garage > Trailer Tech
Trailer Tech The Follower
Old 04-07-2011, 11:31 PM
Donnie1030's Avatar
Donnie1030 Donnie1030 is offline
Friends
Default Toy hauler upgrades
Has anybody heard of a kit to beef up the weight capacity in the floor of a garage in a toyhauler. I have a 42 foot cyclone fithwheel toy hauler three axels and I would like to hall my tj in but the weight capacity is only 3000... I can beef up the door thats no problem but the floor is a different story..........
EZ MONEY
Old 04-08-2011, 10:02 AM
Dogfather's Avatar
Dogfather Dogfather is offline
The One that Screws it up
or is it?
Maybe it's the springs and frame, or the hubs on the axles, or the tongue capacity. Look at the GVWA on the trailer itself when you add all you wet goods, water and such you could verry well wind up with 10 to 15,000 lbs in that alone, then you add 7,000lb Rig Shoowwweee.
As you see I'm not beyond over loading my rig either.
How much does your tow rig weigh? when you start hauling more weight behind you that your driving things could get squirrely in a second...
Don't mind me I'm not a professional just an armature wanting to tow it all....
Edward Campbell
Interim Washington State Executive Director
Webmaster 2008-2014 Glad I could help
Region 2 Director 2008-2010 Glad to help.
President DogpoundOffroad
Old 04-08-2011, 10:11 AM
Donnie1030's Avatar
Friends
Its the floof im wooried about, The trialer is a fithwheel with three axels. The floor is rated for 3000 lbs, I ran my tj across the scales fully fueled with me in it and it only weighed 4250 so that would put total gross at 17920 lbs. I just don't want to blow the floor out of a $70,000 trailer my wife would kill me...... I thought maybe there was a kit for that but I haven't found anything yet !
EZ MONEY
Old 04-08-2011, 11:47 AM
Rockaholic Rockaholic is offline
Friends
I had a toy hauler that we carried a TJ in. Before I bought it I called the factory and asked about hauling the Jeep. They said the weight was fine but I needed to beef up the floor. After running the numbers I decided to use 3/16's inch diamond plate on the floor that ran the length of where the jeep parked. Then I went to the next size up axles because my wife liked to load every compartment. If you need to stiffen the frame, I would bridge it with flat stock at least 1/4 inch thick the same width as the frame. Then use round tube in varying length to make an inverted truss under the frame. Any good shop could do it if it is above your welding/time capabilities. I hope this helps. Your only other option is to get a Motorhome and a trailer. The door may need some beef also. Use Aluminum channel for the door.
Jon Pyland
Deschutes County 4-Wheelers
Bend, Oregon
Old 04-08-2011, 12:49 PM
Donnie1030's Avatar
Friends
Yeah I think im going to beef up the floor my self and the door, Ill throw in some more cross members and some heavy duty diamond plate on the door and floor. Thanks for the input..
EZ MONEY
Old 04-12-2011, 04:03 PM
Dave McMains's Avatar
Dave McMains Dave McMains is offline
"OLD GUY"
I bought Jon's Toy hauler from him last year and it is a very good and stable way to haul! He did a great job on beefing up the trailer. Best purchase I ever made.
Dave McMains
PNW4WDA Treasurer
NRTP selection Committee member
Cle Elum Ranger Dist. ORV Ranger
Build your rig to fit the trails, don't change the trails to fit your rig!
Old 04-12-2011, 10:52 PM
Donnie1030's Avatar
Friends
As soon as I get some time im going to beef up the floor with some more cross members under the floor and beef up the door, ILL put some heavyduty diamond plate on the top floor and door ....
EZ MONEY
Old 04-13-2011, 07:10 PM
Peppermint Patti's Avatar
Peppermint Patti Peppermint Patti is offline
Forum Leader
Patti Pyland
Oregon Executive Director Staff
PNW Forum Leader Team Member
Region 6 Delegate
Bend, Oregon
Old 04-15-2011, 11:54 PM
JKZ Motorsports JKZ Motorsports is offline
Friends
X2
We looked at doing the same thing. Chances are the tires will end up in between the floor joists and with the constant bouncing the rig will do.........the tires will blow through the floor.
