Go Back   Pacific Northwest Four Wheel Drive Association > Tool Bag > Vendors
Vendors Links and forums
Old 01-28-2012, 03:03 PM
T M I's Avatar
T M I T M I is offline
Weld on Beadlock
Default Weld on Beadlocks
Total Metal Innovations is manufacturing Weld-on Beadlocks in the Pacific Northwest.
CNC Cut Weld-on Beadlocks standard and custom designs.
32 bolt Rings. Hardware (bolts, nuts, washers) not included.
$200 for a set of beadlocks for 4 wheels with the standard designs (#1-12).
15 Inch standard designs set to install on 4 wheels $200
16 Inch standard designs set to install on 4 wheels $210
16.5 Inch standard designs set to install on 4 wheels $220
17 Inch standard designs set to install on 4 wheels $230
18 Inch standard designs set to install on 4 wheels $250
20 Inch standard designs set to install on 4 wheels $275
Custom Design pricing on a per design basis. Most Designs even custom are included at the prices listed above.
1/4" thick steel rings
We can also fill your custom bracket and tab needs.
Total Metal Innovations 541-223-8608
For OFFROAD USE ONLY. All welding should be completed by a certified welder.
There is a 1-3 business day lead time on these.
Old 01-28-2012, 03:17 PM
T M I's Avatar
Weld on Beadlock
Forgive me if we need to become a vendor I did not see a area to do so. If so please send me info on becoming a vendor on the forum.
Total Metal Innovations is also looking for a few events in our local area to DONATE some weld on beadlocks for a worthy cause.
Thank you,
Tyler
Old 01-28-2012, 04:12 PM
Winter convention is right around the corner. Its our largest meeting of the year. You might contact Kyle (his info is on the front page) about setting up a vendor spot and donating a set of your beadlocks for the raffle. Welcome to the site
Wa. State Director PNW4WDA
Old 01-28-2012, 05:59 PM
T M I's Avatar
Weld on Beadlock
Thank you for the info. I just send Kyle a email about both subjects at hand.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
