Go Back   Pacific Northwest Four Wheel Drive Association > Rigs > Jeeps > TJ's
TJ's Coiled up
Old 01-11-2009, 09:44 PM
Wildman's Avatar
Wildman Wildman is offline
Default Wildman's TJ
Well my TJ has been thru a lot in the time I have had it. Here is what I started with.
I bought it in Sept of 2002. It had a Pro-Comp Stage II 4" lift kit. It had never been off-road before I bought it. Funny thing is it ran around Yakima with 33X14 Boggers. The gal that owned it just like the way it looked.
Then I got deployed to Iraq in Oct 2004. The Jeep sat while I was gone. I come home early due to being wounded. I had the Jeep parked right outside my window so I could look at it. As soon as I could drive it (which was before I could walk BTW) I took it down to Swabbies and had 35X13.50 tires installed. Then I picked up a Tera Flex long arm kit & Tera Low 4:1 kit & a 2LO kit. The Jeep stayed like that for a while.
Then I got a wild hair up my BUTT and decided I wanted to build a Jeep I would wheel for the next 20 years.
I started with a V-8 swap. It is a 1999 Dodge 5.2L from a Dakota. I am running a 4 speed auto behind it.
I wanted more gear selection so I ended up with a STaK's Monster Box t-case with 3.05:1 & 5.44:1 low ranges.
For the front axle I built a Ford HP44 axle narrowed to Waggy width so I can run off the shelf axles.
Rear axle is a Tera CRD60 HP custom axle. Both axles have 5.13 gear, ARB lockers and CroMo axle shafts. The front axle also has Longfield 300M u-joints.
I liked the design of the Nth Degree longarm suspension they had for the TJ so I went with that kit but with a twist. Instead of running coil springs or coilover shocks I decided to run air bags in a kit from Off-Road Only called the AiRock kit.
I have Posion Spyder front tube fenders and rear crusher corners with tube flares.
WILDMAN
AKA:Rick White
wildman@4x4nut.com
www.4x4nut.com
2008 Dodge CTD MegaCab
1997 Jeep TJ SE
2010 Road Glide Custom
2000 Polaris 700RMK
1993 SkiDoo Mach 1 XTC
2006 Yamaha Raptor 700
Old 01-11-2009, 09:54 PM
Wildman's Avatar
This past winter I decided that the Toyo M/T tires were not cutting it. So I pondered for a long time as to which new tire I was going to try out. Well I decided on the TSL SX tire. And figured out that I wanted to go TALL so I went with 38X12.50X16.5 tires. And since I wanted beadlocks I went with a very good DUAL beadlock rim----Military H1 (Hummer) rims.
I cut the centers out of the rims and welded in new centers which gave me a 4.25" BS and now a 5 on 5.5 BP.
Then took them down and had them powder coated.
There are a lot of other mods I have done to this Jeep. It would take me a few more pages and tons of pictures to list ever thing.
WILDMAN
AKA:Rick White
wildman@4x4nut.com
www.4x4nut.com
1997 Jeep TJ SE
2000 Polaris 700RMK
Old 01-11-2009, 10:14 PM
JeepNirvana's Avatar
JeepNirvana JeepNirvana is offline
<----Busy Wild
Freekin Awesome Wildman.
Dan Rheaume
RAY-OME
Outdoor 4x4's
Cascade4x4s
Webteam member
Forum Admin
Old 01-12-2009, 12:31 AM
Duck Dodgers's Avatar
Duck Dodgers Duck Dodgers is offline
Aimless Wanderer
Location: Somewhere between the Port of Indecision and South of Disorder
Nice Wildman, great job on the wheels. Nice build. And please by all means post up yur pics of your other mods.
Originally Posted by MarkoPo View Post
We all know in the beginning God created the earth and the Heavens. On the second day God created man and Jeep. Man had too much fun so God created woman. Man hasn't had near as much fun since.
Old 01-12-2009, 12:10 PM
wood's Avatar
wood wood is offline
Pimp of the woods
Nice!!
Strange things are afoot at the Circle K
Old 01-12-2009, 11:40 PM
Luke May's Avatar
Luke May Luke May is offline
Parliamentarian
Keep It coming! like seeing mods pic.
Old 01-13-2009, 02:13 AM
Wildman's Avatar
Luke,
Nice to see you here. Hope you stick around.
Rick
WILDMAN
AKA:Rick White
wildman@4x4nut.com
www.4x4nut.com
1997 Jeep TJ SE
2000 Polaris 700RMK
Old 01-13-2009, 02:55 PM
Very cool build! :super:
