Go Back   Pacific Northwest Four Wheel Drive Association > Wheeling > Idaho Trails
Idaho Trails Mountain High
Old 05-07-2010, 08:23 PM
paulp575 paulp575 is offline
Default CdA River Ranger District (Idaho Panhandle NF) Motor Vehicle Use Maps
The 2010 Couer d'Alene River Ranger District (Idaho Panhandle National Forest) Motor Vehicle Use Maps (MVUMs) are out!
You can download a copy of the map from this website:
http://fs.usda.gov/wps/portal/fsinternet/!ut/p/c5/04_SB8K8xLLM9MSSzPy8xBz9CP0os3gjAwhwtDDw9_AI8zPwhQ oY6IeDdGCqCPOBqwDLG-AAjgb6fh75uan6BdnZaY6OiooA1tkqlQ!!/dl3/d3/L2dJQSEvUUt3QS9ZQnZ3LzZfMjAwMDAwMDBBODBPSEhWTjJNMD AwMDAwMDA!/?navtype=BROWSEBYSUBJECT&cid=stelprdb5144787&navid=360000000000000&pnavid=null&ss=110104&position=Not%20Yet%20Determined.Html&ttype=detail&pname=Idaho%20Panhandle%20National%20Forests-%20Maps
(sorry about the long link)
Just be aware the maps are very large! If you want to print out a small section of a given map, you can do so by displaying the area on your screen and then printing the "Current View". That will at least give you a small section of the map that you could use in the field.
Be sure to take a look at the tables on the reverse side of the map. They indicate the time period a trail is open. On the front side of the map, if a trail has gray shading along both sides of the trail, that means there is a limited time when the trail is open. Check the trail number and then find the trail number on the reverse (table). It will show the mileage and dates open.
Questions? Contact me for more information.
Paul
Spokane WA
07 Jeep Rubicon AT Soft top
Member of:
Washington Off Highway Vehicle Alliance (WOHVA http://www.wohva.org)
North Idaho Trail Blazers (NITB; http://www.nitrailblazers.org)
