Go Back   Pacific Northwest Four Wheel Drive Association > Wheeling > Washington Trails > Rimrock
  #41
Old 08-10-2010, 08:55 PM
Originally Posted by jim putman View Post
Most PNW4WDA members have learned to build their rigs to fit the trail. They do not expect the to change the trail to fit their particular rig.
When did they learn this?
The trails are much wider than when my dad was wheeling back in the 70's...so if the PNW4WDA members are building their rigs to fit the trail, why don't more members run a wider width rig?
If a new/young wheeler was to start wheeling today...building a rig to fit the trails would = an 80 inch plus wide rig.
Your logic is screwy....just because the FS rules are set to 72 inches, it doesn't mean that is the widest rig you can take down the trail without climbing trees.
Old 08-10-2010, 09:09 PM
Heres the problem with gate keepers alone. A gate keeper will NOT keep a wider rig out. In fact not much of anything can stop a well set up buggy off a trail thats to narrow for it. We all know that some people out there have no issue with climbing up trees and stripping the bark off 8 feet off of the ground. The only real way the FS can moderate use of a trail is to post restrictions and then back them up with heavy fines. Nothing stops someone from doing something like the possibility of a heavy fine. BTW there already are gate keepers on this trail. Their called trees and someone has already cut down several of them because they couldnt fit. See the need for fines now ?
I take exception to your use of the term "buggy"...there are many types of rigs that could navigate a narrow trail...using the term "buggy" is stereotypical & unfair...please find a different terminology. I suggest using "wider rig" instead.
Old 08-10-2010, 09:22 PM
I use the term "buggy" because a "buggy that is say 84 inches wide is quite capable of squeezing between trees or obstacles much narrower than that by simply driving up the side of said obstacle sometimes even driving on their side to fit by. A average "wider" wheeling rig is simply not capable of this type of manuver.
Old 08-10-2010, 09:34 PM
I call bullshiat on this one...a flatty on full widths would fit your "buggy" definition. Just the same...this would apply to a CJ, YJ or TJ.
Please discontinue your use of the term "buggy" as a generalization for wider rigs.
Old 08-10-2010, 10:02 PM
We have all seen it and you know its true. I didnt create the term and you shouldnt be so defenceful of it. Buggys / fullsize both differant animals and we all know it..
Oh and NO
Old 08-11-2010, 10:20 AM
Binder's Avatar
Binder Binder is offline
Has some friends
My .02c....I don't see the big deal with using the word "buggy" as a generalization. "Wider rig" could be a fullsize Bronco or Hummer. "Buggy" gets the point across.
Using the word is no big deal as long as the context doesn't change to "Buggies need to stay off the trails" because then things would need to be more specific....
But hey, whateva.
And Jim I believe the gate keepers could be built to successfully keep "buggies" out if this were the goal.
Rick Wiltfong
Old 08-11-2010, 10:30 AM
Binder's Avatar
Has some friends
Zbd74......Your posts read as though you have a issue with the width restrictions only because your rig is just barely too wide. Ask yourself if you had a rig that fit the trail would you still have an issue with the restriction? There has to be a hard number on the width and someone's going to be just too wide, unfortunately this time it happens to be you....Or am I misunderstanding your posts?
Rick Wiltfong
Old 08-11-2010, 11:22 AM
To establish a "Gatekeeper" at this location would require much work and expense. Numerous bypass's could be made to go around. Consider the sign posted with the restrictions and CFR with potential fines as the "Gatekeeper".
As seen with the new Travel Management Vehicle Road maps in the Mt Baker/Snoqualmie the requirement for signs will soon go away when the Okonogan/Wenatchee implements the Travel Management plan.
Know before you go is where all this is headed.
Old 08-11-2010, 11:29 AM
Binder's Avatar
Has some friends
Originally Posted by Merrick Graves View Post
To establish a "Gatekeeper" at this location would require much work and expense.......................
I was refering to gatekeepers in general.....
Know before you go may sound great on paper but unless you plan to do a full time stakeout it isn't going to do much. Once the signs are gone rigs that shouldn't be there will run the trail and trees will begin to go away. You may or may not fine people for this but the sad reality is the trail will suffer.
Rick Wiltfong
Old 08-11-2010, 11:30 AM
You have a life's worth of work ahead of you to change the generic term "Buggy". Almost everyone I work with uses the term. Every rig that does not resemble stock or slightly modified is often reffered to as a "Buggy". Whether it's an Enforcement specialist or Policy development specalist the term is used and thrown about.
