Go Back   Pacific Northwest Four Wheel Drive Association > Tool Bag > Garage > RV Tech
RV Tech Big or Small
Old 07-15-2010, 07:31 AM
Default Towing a trailer
Hey Bill I want to start this by Thanking you for taking the time to post these things, unless your into RV's you don't see the value,
Ok here is my question
Tell me what you know that I need to know when I start looking for my New Class a Diesel pusher.
I have 2 sammys prolly at the most 3k each and a 26 foot trailer that i haul them on..
I'm looking at possibly buying a 26 foot enclosed trailer What's your opinion on that?
I appreciate all your doing and all the input this thread gets
Old 07-20-2010, 10:42 AM
Bump Bump? anyone Home?
From what I have read so far I need well maintained Brakes on the trailer and a load leaveling outfit, and at least a 330 Hp Diesel? Can I do it with less?
Old 07-20-2010, 05:39 PM
Dianamal77's Avatar
Dianamal77 Dianamal77 is offline
Super Moderator
I'm not super knowledgeable Edward, but I can confirm you want at least a 330HP diesel, especially if you're planning on towing an enclosed trailer. Otherwise it has to work to hard and the exhaust gas temps climb to high, causing you to have to let up on the throttle, which makes you slow down, etc.
An enclosed trailer is great, but you will end up putting a lot of stuff in it (hence the need for the bigger diesel). We have a triple axle and Rob loves it.
Diana Stafford
Cascade 4x4s
Overbored Racing
Countyline Offroaders
Region 2 Membership
Real Deal Doe Run Member
Old 07-20-2010, 09:13 PM
I think you're looking for an 8.3l Cummins minimum with 6spd Allison. I recall the 6spd Allison was capable of an exhaust brake. Not all 4spd Allison's were capable of an Exhaust brake. I think the enclosed trailer is the real wild card. You might need more engine.
Old 07-21-2010, 07:32 AM
So your saying I need to look for an Exahust brake?
Old 07-21-2010, 07:04 PM
gunrunner gunrunner is offline
The kind of weight your talking about, don't leave home without one.
Harney County High Desert Wheelers, Steen Mountain Advisory Council and DC4W.
Rubicon LJ, supercharger and 35s
Old 07-21-2010, 09:26 PM
I use my exhaust brake all the time. I can go down most/all mountain passes without using vehicle service brakes. This keeps the vehicle brakes cold. Cold brakes always work better. Dan R cooked his vehicle service brakes on the way to the Rubicon in 2005. This required complete brake system replacement after the trip. He probably could have gone with an immediate replacement. This was on his pickup. I'm pretty sure motorhome brakes are alot more expensive.
Old 07-22-2010, 08:15 AM
Thank you verry much for the comments
Do most of the Diesel pushers come with Ehahust brakes?
if not are they easy to install?
Old 07-23-2010, 09:45 PM
The 8.3l exhaust brake is a butterfly valve in the turbo elbow. Not sure on the difficulty. The engine is typically below the master bed. The few I've seen is plenty of room to work. However, some areas of the engine are easier to access than others. Some exhaust brakes are vacuum driven while others use positive air pressure.
http://www.shopatron.com/products/pr...googleshopping
Old 07-24-2010, 08:08 AM
Thanks Bill I'll Be back once I pick up My DP
