Go Back   Pacific Northwest Four Wheel Drive Association > Wheeling > Racers Edge
Racers Edge Race Repair Repeat
Old 03-27-2011, 08:46 AM
Dianamal77's Avatar
Dianamal77 Dianamal77 is offline
Super Moderator
That's the plan, but they are still being reviewed and edited. When the final version is complete, they will be posted under the competition tab.
Of note, there have been some rule changes. I'll post them up shortly.
Diana Stafford
Cascade 4x4s
Overbored Racing
Countyline Offroaders
Region 2 Membership
Real Deal Doe Run Member
Old 03-27-2011, 08:49 AM
Dianamal77's Avatar
Super Moderator
Default New rules 03/2011
1st All Automatic Transmission must have minimum of 3/8 conveyor belting, 1" head of flywheel to tail shaft that is securely fastened, with recommended explosion proof blankets and or bell housing, transmission cover that is SFI approved.
2nd All Competition vehicles are required to have both front and rear drivelines a minimum of inch thick by 1 inch wide with a minimum of 2 inch clearance around driveline, securely fastened. Drive line loop is to be center to 2/3 to front of vehicle.
3rd Fabrication bars: Minimum of 1 5/8 OD tubing with a minimum of 0.090 wall thickness, or 1 tubing with a minimum of 0.120 wall thickness. No Threaded fittings, Aluminum and stainless not allowed.
4th Batteries must have metal hold downs over top of battery. Secured to vehicle OEM mounts accepted in Street & Trail class, battery terminals must be protected (covered) from shorting out.
All above rule are in Effect: Immediately.
Any questions please call Dave Taylor
PNW4WDA Competition Chairman
Home 360-668-0719
Cell 206-491-0909
Diana Stafford
Cascade 4x4s
Overbored Racing
Region 2 Membership
Old 03-27-2011, 01:37 PM
Lucky's Avatar
Lucky Lucky is offline
Thank you!! This will make it a lot easier to decide just what and how to make the necessary changes.
Old 07-29-2011, 07:46 PM
Little Toot's Avatar
Little Toot Little Toot is offline
curious as to when the 2011 race rules will be posted? I have a buddy interested in racing in summer convention and would like to know myself or else I will be prepared under the 2006 rule book.
Don Morrell
Owner of the Little Toot:Cob:.
V.P. and delegate of Bullshifters 4x4 club
www.myspace.com/donmorrell
Old 07-29-2011, 07:54 PM
Binder's Avatar
Binder Binder is offline
Has some friends
Don the rule changes are in this thread.
http://www.pnw4wda.org/forums/showthread.php?t=2407
These are the changes to the 2006 rules to make them current. If you have specific questions post up here and we'll do our best to answer.
Rick Wiltfong
Old 08-01-2011, 09:46 PM
thanks Rick!
Don Morrell
