Go Back   Pacific Northwest Four Wheel Drive Association > Tool Bag > Vendors
Vendors Links and forums
Old 10-14-2010, 09:55 PM
4WheelingPlus.com 4WheelingPlus.com is offline
Member since 1996
Default XHD Winch Recover Kit - 30,000 POUND MODEL!!!
This is a new HEAVY DUTY winch recovery kit that is rated at 30,000 pounds!
Most of the others are rated under 20,000...
More details: http://store.4wheelingplus.com/prodd...?prod=15104.28
The Rugged Ridge XHD snatch block is much larger than the standard Rugged Ridge snatch block:
30,000lb Capacity vs. 20,000lb Capacity
This durable 9 long pulley is constructed from 1/4 cold rolled steel and is suitable for use up to 30,000lbs. For use with winch cables up to 1/2 in diameter.
The Rugged Ridge XHD d-ring/shackles are much larger than the standard Rugged Ridge d-rings as well:
9,500lb Capacity vs. 13,500lb Capacity
