Old 01-08-2011, 03:11 AM
frank frank is offline
Default neet help (please read)
i have a 88 xj with a 5inch lift it started hoping tonight whal in 2wd it feels like the drivers front has anyonh incured this problem and what did you do to cure the problem as this is my daly driver
Old 01-09-2011, 01:01 PM
Power Wagon Power Wagon is offline
Most likely problem is a broken belt in the tire carcass (casing).
Old 01-09-2011, 10:18 PM
Bad Ujoint?
Old 01-09-2011, 10:32 PM
Stuck axle disconnect?
Old 01-13-2011, 10:50 AM
Bad tierod end
Old 01-14-2011, 12:49 PM
If it has picked up a "death wobble" shake in the front end and steering wheel, check all the rod ends and the steering box bolts, and the unit bearings in the wheel hubs. If a tire hop, swap front to rear and if it moves then the tire is either out of balance or like was said a belt let go. My death wobble is a steering box getting loose (only about a 1/16 turn on the bolts)
Old 01-16-2011, 10:57 AM
Crawl Mama's Avatar
Crawl Mama Crawl Mama is offline
Originally Posted by Dogfather View Post
Bad tierod end
We had this wabble problem on the way from Sunnyside to Selah and could have killed us on the freeway but luckly it did not brake until we were turning around in a driveway, I would advise not driving it over 35 mph if at all until you know infact what is wrong, don't take any chances.
Cindy Waterman
All Wheelers Off Road Club
PNW4WDA Region 4
Yakima/Kittitas Forest Watch Member ykfwa.org.
DNR Volunteer
82 Toyota motified lift, marlin crawler.
88 Charokee 4 door, modified lift.
