Go Back   Pacific Northwest Four Wheel Drive Association > Wheeling > Land Matters Discussion Area
Land Matters Discussion Area Discussion Relating to Your Land/Legislative Issues
Old 07-29-2011, 08:50 PM
paulp575 paulp575 is offline
Exclamation Re: Okanogan-Wenatchee and Colville NFs Forest Plan Revision
Comment Period Extended!!
Just received the following:
USDA FOREST SERVICE
NEWS RELEASE
Colville and Okanogan-Wenatchee National Forests
Forest Plan Revision Team
1240 Second Ave. South,
Okanogan, WA 98840
http:/www.fs.usda.gov/goto/okawen/plan-revision
E:mail: r6_ewzplanrevision@fs.fed.us
For immediate release: July 29, 2011
Contacts: Debbie Kelly, Plan Revision Team, Public Affairs Specialist, (509) 826-3275
Roland Giller, Okanogan-Wenatchee Public Affairs Officer, (509) 664-9314
Franklin Pemberton, Colville National Forest, Public Affairs Officer (509) 684-7177
Comment Period Extended for Forest Plan Revision
Proposed Action
OKANOGAN In response to requests, the Colville and Okanogan-Wenatchee National Forests are extending the comment period for the Forest Plan Revision Proposed Action for an additional 30 days.
The original 60-day comment period was June 30 through August 29, 2011. With the extension, comments are now due no later than September 28, 2011. For more information please contact Debbie Kelly, 509-826-3275 or check out the project website where information on the proposed action, comment process, project timeline and public meeting schedule can be found: http:/www.fs.usda.gov/goto/okawen/plan-revision.
XXX
Forest Plan Revision for Colville, Okanogan & Wenatchee National Forests
Okanogan Valley Office
1240 Second Avenue South
Okanogan, WA 98840
Email: r6_ewzplanrevision@fs.fed.us
Web site: www.fs.fed.us/r6/wenatchee/forest-plan
Contacts: Deb Kelly: Public Affairs Officer (509) 826-3275
Margaret Hartzell: Planning Team Leader (509) 826-3275
Paul
Spokane WA
07 Jeep Rubicon AT Soft top
Member of:
Washington Off Highway Vehicle Alliance (WOHVA http://www.wohva.org)
North Idaho Trail Blazers (NITB; http://www.nitrailblazers.org)
Old 08-08-2011, 10:04 PM
Grumpy's Avatar
Grumpy Grumpy is offline
Anyone want free BBQ
http://action.sierraclub.org/site/Ca...src=211HRHEW01
Dave Walters
Tri Cities Peak Putters
Land Use Coordinator
www.peakputters.com
It's a Scout thing
Old 08-19-2011, 12:38 AM
WAYCRAZY WAYCRAZY is offline
Well I did attend the Yakima meeting . The place was packed. The USFS did there usual Job at skirting and squirming around what they were up to. Most of the room was interested how many roads and trails that would be closed . The USFS answered this question with ...
This isn't going to be discussed at this time because it falls under the Naches travel management plan
And in some factual way that is a true answer. But this Forest plan revision is the frame work on which land closures will be made in the travel management. They also said that the Forest plan revision wouldn't be finished by the time the Travel management was finished . So there shouldn't be any worries. But they are working closely together to make sure all the Travel management would coincide with the forest plan revision. So that tells me that the USFS has a end game plan and they are being patient enough to get all the nails properly pounded in the coffin so they don't come loose. And as said earlier in the discussion about what areas are getting zoned as what. Such as most of the Little Naches is going to be active restoration 2. Which will give the USFS the right to make a Wheeling season like they do a hunting season. Unlike the way it is managed now were they can only do emergency forest order closures. I can almost promise that is the way the Head Naches district ranger wants to go! And it will look like this June 15th-July31st. The start date:To make sure all the ground is rock hard and dry. The end date: Must shut down the forest to motorized use due to fire danger.
Old 08-19-2011, 12:58 AM
Default Re: Okanogan-Wenatchee and Colville NFs Forest Plan Revision
Originally Posted by WAYCRAZY View Post
Well I did attend the Yakima meeting . The place was packed. The USFS did there usual Job at skirting and squirming around what they were up to. Most of the room was interested how many roads and trails that would be closed . The USFS answered this question with ...And in some factual way that is a true answer. But this Forest plan revision is the frame work on which land closures will be made in the travel management. They also said that the Forest plan revision wouldn't be finished by the time the Travel management was finished .
Interesting comments. It appears the OK-WEN NF is being managened quite differently than the Colville. Although the Colville has officially completed thier "forest-wide" TMP, they have stated and proven (at least via their first EIS released since completing the forest-wide TMP) they are not finished. They are now looking at individual areas of the forest where they can create a "good rider experience." Basically they want to create loops and connecting trails rather than many of the current "out and back" trails.
That's a really different interpretation of the Active restoration 2 that I'm reading in the Colville Proposed Action. In there, they state the 2 means roads would be limited to an average of 2 miles per square mile (same with the Active Restoration 2, but 3 miles per square mile). In the "Background to the Proposed Actions" sections (both AR 2 and AR 3), they state "...this management area will be defined by roaded landscapes in areas...". I don't know if you are a 4x4er, an ATVer, or a dirt biker, but as a 4x4er I am interested in trails, not roads so your definition of potentially open or closed areas may be different. Trails and roads are not the same - according to the USFS personnel at the Spokane meeting.
Have you sat down and read through the ENTIRE Proposed Action and downloaded any of the GIS files? If not, I'd encourage you to do this. They have GIS files that are compatible with Google Eearth. Although those files are incompelete - as far as delineating the specific areas by textual reference, you can at least physically see the areas and how they intend to classify them.
If you need some help with the GIS data files, please e-mail me and I'll do what I can.
Paul
Spokane WA
Member of:
Old 08-22-2011, 11:21 AM
I have read the proposal front to back. Here is were I am forming my opinion on active restoration 2.
This was quote was taken from:
Page 59
http://www.fs.usda.gov/Internet/FSE_...rdb5312322.pdf
Recreation setting and activities - The area supplies a variety of dispersed or developed summer and winter recreational activities that are motorized and non-motorized. Seasonal use restrictions occur for the purpose of resource protection or recreation management. Recreational use is generally dispersed. Recreational developments, such as campgrounds and trailheads, are imbedded within the area, but are their own separate management area. Human-caused changes from management actions related to recreation are generally limited in scale, can be visually evident, and reflect a roaded natural recreational opportunity setting.
I am a 4x4 and dirtbike user and trails are my main focus . But I believe all motorized roads or trails could be interpreted ruled by active restoration 2 that appears labeled as such on the map. What if they close access roads to your trails then what?And as I previously stated this creates a frame work for the travel management plan which directly effects trails.
Old 09-18-2011, 12:01 PM
Exclamation Colville and Okanogan-Wenatchee National Forest Plan Revision - My Comments
The Colville and Okanogan National Forests are currently in the process of revising their Forest Plans. They are asking for comments to be received by September 28, 2011.
You can mail your comments to the following address:
Colville and Okanogan-Wenatchee National Forests Plan Revision Team
Okanogan WA 98840
Or your can e-mail your comments to: r6_ewzplanrevision@fs.fed.us
I would strongly encourage you to e-mail your comments in that if you (postal) mail them, you will not know if they reached the forest plan office.
If you do not responded to the current proposals, according to the USFS, you will not have a basis to comment on any further public comment periods regarding the forest plan revision, so now is the time of comment!
You can review the Proposed Action document of the forest plan revision at this web site: http://www.fs.usda.gov/goto/okawen/plan-revision .
On that page you will see a link to the Proposed Action - that is the document the forest plan revision team is requesting comments on.
Because the document is so extensive, the Forest Plan Revision Team has published a six page "Reviewer's Guide" to assist one in reviewing and commenting on the proposal. The last two pages of the Reviewer's Guide contains a sample Comment Form that could be used for providing comments. Discussion with Plan Revision team members advised me that you do not have to use that form; it's just a helpful guide!
There is a lot of information contained in the Proposed Action document. The Colville NF Proposed Actions document is 79 pages long! Probably the most interesting part is the "Proposed Actions" section covering pages 23 through 72. Within those pages, it is further broken down by topics and beginning on page 51, it is broken down by Management Area.
Each of the Proposed Actions sections is broken down further by --
Proposed Actions
Tools to Expect (management activities and monitoring activities)
It is the Proposed Actions section the Forest Plan Revision Team requests comments on.
Here's the breakdown of the Proposed Actions sections:
Landscape Character and Dynamics:
Aquatic and Riparian Systems
Plant Habitats
Vegetative Systems
Wildlife Habitats
Social Systems:
Access System
Livestock Grazing
Recreation
Renewable Forest Products
Scenery
It should be noted that some of the management areas listed above are included in the following management areas!
Management Areas
Active Restoration 3
Administrative and Recreation Sites
Backcountry
Backcountry Motorized
Experimental Forest (Okanogan-Wenatchee Forest only)
National Scenic Area (NSA) (Okanogan-Wenatchee Forest only)
Nationally Designated Trails
Research Natural Areas (RNAs)
Riparian
Scenic Byways
Snoqualmie Pass Adaptive Management Area (Okanogan-Wenatchee Forest only)
Special Interest Areas (SIAs)
Wild and Scenic Rivers
Wilderness - Congressionally Designated
Wilderness - Preliminary Administratively Recommended
Wilderness Study Area
Note: The Wilderness - Preliminary Administratively Recommended are the areas being recommended for Congressionally-Designated Wilderness.
Below are my comments concerning the forest plan revision. Because my main area of interest is in 4x4ing in the Colville National Forest, my comments are limited to the Colville NF portion of the Proposed Action. I also have an interest in ATVing so some of my comments reflect that interest as well.
I ask that you do not copy my comments verbatim because if you do when the forest plan revision team receives exactly the same comments from more than one individual, they consider all those responses as one response. You may use my comments for the basis of your response.
If there is something in the Proposed Action you do not understand - especially if it relates to the Colville NF portion, please feel free to contact me for clarification. I have reviewed the Proposed Action document numerous times to obtain a better understanding of it's contents.
So with that aside, here's my comments - they are listed by pages - front to back:
Recreation (pages 44 through 46):
Proposed Actions (page 46): On pages 74 though 76, under "Process Information - Topics Not Addressed in the Revised Forest Plan", you mention on page 75 under Travel Management that "site-specific routes and areas for motor vehicle use are not made in this forest plan". While that is fully understood, you need to ensure that a statement that "the Travel Management process(es) would continue under the revised forest plan" is included in the new forest plan. That fact should be mentioned under Recreation - Proposed Actions on page 46. Other than the reference on page 75, I am not aware of any other mention of the Travel Management process which could be meant that the Travel Management process would/may not be continued under the revised forest plan.
Access System (page 41):
Your statement "The desired condition is to reduce the miles of inventoried unauthorized roads, and minimize the development and proliferation of new unauthorized roads and trails" is unacceptable. The specific portion that I disagree with is "inventoried unauthorized roads."
Rationale for disagreement: Rather than reducing the miles of unauthorized roads, many of which have been in place for more years than most of us can remember, why not conduct an analysis, which would include current usage of the roads, to determine if they are currently being used. If such is the case, then why not convert them to authorized roads? By adding mileage to the current inventory of authorized roads, you may be reducing the use of unauthorized roads.
Trail management (under Access System) (page 42):
Your statement "Close and decommission approximately one mile of user-created routes annually." I disagree with this statement.
Your statement "Designate 30 miles of ATV trail on the Colville National Forest". I disagree with this statement.
Rationale for disagreement: Why only 30 miles over the period of the forest plan (approximately 15 years)? Several places within the Proposed Action you state that ATV use within the Colville is increasing so why limit it to just 30 miles for the duration of the forest plan? While it is understood there are budgetary issues involved, a specific statement as to the number of miles to increase indicates you do not value ATV use in the forest. Why not state something like "Within budgetary limitations, increase annually the number of miles of ATV trails within the Colville National Forest."
Backcountry Motorized (page 59):
Your statement "... and include the 2001 Inventoried Roadless Areas and the potential wilderness areas identified in the plan revision wilderness evaluation process. A few smaller unroaded areas are also included, as well as several places where previous decisions have slated removing system roads.
These areas are unroaded ...". I disagree with this statement.
Rationale for disagreement: According to the Google Earth data files provided on the plan revision web site, some of the Backcountry Motorized management areas do included roaded areas, i.e., the Mack/King Mtn. trail (trail # 98) lies within a management area designated as Backcountry Motorized as well as the Twin Sisters trail (trail # 109).
I do recognize that the US Forest Service considers roads and trails as two totally different things, but there is no mention in most of this Proposed Action about trails, except in one or two places where the word "ATV" precedes the word "trails".
The fact that some of the best 4x4 recognized trails in the entire Colville NF lie within your proposed Backcountry Motorized areas! This fact needs to be addressed!
Activities (under Backcountry Motorized) (page 60):
Your statement "These areas supply a variety of dispersed summer and winter recreation activities in an unroaded setting" again does not consider the above mentioned 4x4 trails. These need to be addressed somewhere in the Proposed Actions document.
Paul
Spokane WA
Member of:
