Go Back   Pacific Northwest Four Wheel Drive Association > Around the Camp Fire > Camp Fire Chat
Camp Fire Chat Pull up a chair sit down and talk
View Poll Results: How wide is your rig?
Under 60" 0 0%
61" - 66" 2 6.25%
67" - 70" 5 15.63%
71" - 74" 9 28.13%
75" - 76" 6 18.75%
77" - 78" 5 15.63%
79" - 80" 2 6.25%
81" - 82" 0 0%
83" - 84" 0 0%
85" & wider?? Tell us how wide 3 9.38%
Voters: 32. You may not vote on this poll
  #21
Old 03-22-2009, 08:24 PM
The YJ is 74", the '48 is 66", the '52 is 69". Never measured the wagon, but it won't be a tuff trail rig, just for the easy trails.
Old 06-30-2009, 08:12 AM
EagleMark EagleMark is offline
Banned
Well I finally measured my full size Blazer with stock width 3/4 ton axles, Dana 44 front is wider than 14 bolt rear. 36x13.50-15 Irock tires on 8 inch wheels with four inch backspace and it comes out to84 1/2 inches. Should add an inch or so when I do the weld on beadlocks.
I had no idea it was so much wider than the others that voted. But the poll on NWW seems to be wider than this one.
If you think about it and look at a tape measure it's only ten inches? When you look at ten inches in comparison to a truck, jeep, SUV. etc... it's so small... but if you compare ten inches to other things it's very large!
Old 06-30-2009, 11:25 AM
The other thing to think about is that your body on the K5 is probably almost as wide as your axles...I would bet a lot of the rigs on NWW are running full width axles on a jeep/toyota/tube chassis. However, we do have a few folks in WA that run a full width/full size rig...you should check out the guys over on KrazyK5
Old 06-30-2009, 07:17 PM
Nichol's Avatar
Nichol Nichol is offline
rollin
I fit into the majority, but why doesn't it fit on the trailer very well....tight squeeeeeze
Nichol Phillips
Cascade 4x4's Tacoma
El Dorado Dust Devils
Old 06-30-2009, 08:11 PM
The majority of which website??? I guess it depends on how wide your trailer is
Old 06-30-2009, 09:48 PM
Banned
I have visited that site before... just so happens there was an example of one of the trails that has a width restriction and a full size attemping it...
Old 07-01-2009, 07:40 AM
Nichol's Avatar
rollin
Well, this website I would be in the majority. The trailer has wheel wells so that's why it's a tight squeeze- especially since the last modifications to my jeep the spacers take it out a bit.
I like the ability to get through tight places without leaving a mark- not always a possibility- I understand
Nichol Phillips
Old 07-01-2009, 09:26 AM
My trailer is 82" between the wheel wells...I think that is pretty standard for trailers these days. I see you fell into the 71" - 74" catagory on this poll...you must have a little narrow trailer.
Old 07-01-2009, 09:27 AM
What area / trail was that pic taken?
Old 07-01-2009, 10:44 AM
Banned
I think it said Shoestring...
