Ok I just got me a 97 explorer sas 10inch of lift on 35inch bfg,s
When I got it it run awsome now when I start it. It acts like its running put of Fuel???? It isn't when I try and take off it just die ??? Can't rev it up and now it runes like Crap (barley) I don't have the cash to spend on several repairs so I'm hoping to get some advice as to what direction. To start ??????????????????? Any and all help is greatly apreciated ............. It's a ford thing I don't understand |
#2
Fuel filter would be my first bet. bad injector ? Do you have a code reader to see if its tripped any codes ?
Member #40 Hombres jeep club Region 2 landmatters chairman Wa. State Director PNW4WDA |
#3
I don't.
#4
Ok so I let this thing sit for a couple days. And then start it runs awsome then. After a hour+ -
It starts cuting out and get real bad can't get any throtal and it die I'm At a loss .........??????????? plugs n wires ware to start or do I just sell it for what I got in it 97 sas explorer 10inch of lift +- brand new 35-1250-15 bfg allterain |
#5
could be a couple of things, first look to the gas tank vent, how much gas is in the tank, the lower the volume the longer it will run before the vacuum gets high enough to kill the pump and the second would be the pump its self is going bad. loosen the tank cap when it is running bad, and see if it will straighten up if it does you have a bad tank vent if it doesn't, then look at the fuel pressure and see if the pump is getting hot and not getting the volume of fuel to the engine.
Dave McMains PNW4WDA Treasurer NRTP selection Committee member Cle Elum Ranger Dist. ORV Ranger Build your rig to fit the trails, don't change the trails to fit your rig! |
#6
Thanks for the info Dave .... Got to let it sit now as it won't start now.. soon as I'm able to
Check it out I will power my findings...... |
#7
If it starts and runs cold and has no power when warm. I'd say it needs a new catalytic converter. Sounds like it's plugged.
Yesterday is History, Tomorrow ia a Mystery, Today is a Gift! |
#8
Ok so I open the gas cap and nothin changed I pushed the valve
On the fuel rail and ????? Air then gas and if I only push it in a little Get a lot of air then fuel???? |
#9
It don't have a cat on it when I got this it run great cold or warm and. Now runs like crap if I let it sit for a day or too it will fire up and run fine when cold (hour or so) then its as if it starts running out of fuel
When it starts acting up if you give any throttle it will spit and sputter then die and won't start back up For a fire hours or day.......... |
#10
Few hours not fire
| Thread Tools | |
| Display Modes | |
