Old 01-23-2012, 04:46 PM
adrenalizer adrenalizer is offline
unplug mass air flow and see if symtoms change if so try cleaning with brake clean otherwise change sensor
Old 01-30-2012, 11:08 AM
If you are getting air and fuel out the valve, then look towards the pump.
Old 01-30-2012, 11:11 AM
The mass air flow is a good thought, but it has to be plugged in for the engine to run. Clean it with Carb clean and see how it runs, I doubt it will make much difference, as there is air in the fuel. But a clean mass air flow sensor will help in the running so it will not hurt to clean it.
