Go Back   Pacific Northwest Four Wheel Drive Association > Tool Bag > Garage > Tow Rig
Tow Rig Gas or Diesel
Old 03-05-2009, 04:05 PM
CreeperSleeper's Avatar
CreeperSleeper CreeperSleeper is offline
Back up and pipe it...
Default Beefing up the tow rig...
Okay, I know everybody on here is going to say sell it and get a deisel or something of that nature, but I have found myself in a financial place were I am stuck with a 1996 Chevy Tahoe LT as my daily driver and tow rig. It has a Vortec 5.7l in her with a class III hitch and (I believe) 3.54:1 gears...
I don't want to dump a ton of money into this truck as some day I would love to own a real tow rig again. However, what do you guys recommend to make this more tow friendly? I know that it needs overloads of some sort (any recommendations?) and a trailer brake controller (Again needing recommendations). I will also be doing some mild bolt ons to increase power. Any help will be apprieciated.
Chad - KE7VSA
FZJ80 - 37's, lifted, locked, geared, dented
Old 03-05-2009, 09:43 PM
For overloads you could look into SuperSprings. For brake controller I like the Prodigy. Found mine on Ebay for considerably cheaper than Camping World. Don't forget to downshift/turn off OD while towing. Also, recommend a good tranny cooler. Get some good tires for the towrig.
Old 03-06-2009, 08:52 AM
Big K's Avatar
Big K Big K is offline
I know John Galt
I second the Prodigy. Best I've used.
Perhaps airbags in place of overloads?
Weight distributing hitch is a must.
Make certain them trailer brakes are in top notch condition.
Change, it's what you'll have left...
Eric Kosel
Spanaway Moonshiners Jeep Club
My opinions may only make sense to me, read at your own risk...
Old 03-06-2009, 11:30 AM
Thanks for the replies. I would rather do overloads than airbags just because of the price... However, if they are that much better, I could justify it. What brand overload or airbag systems are being used?
Chad - KE7VSA
Old 03-07-2009, 10:39 AM
I'm using Pacbrake airbags on my 3/4ton Dodge. The literature says they're the best. On my application they were a complete bolt on. Installed the air schraeder valve in the driver rear wheel well.
Old 03-08-2009, 08:23 PM
Big K's Avatar
I know John Galt
Firestone "Ride-Rite" has been well spoken of.
I hate overload "slap"...
:cool_shades:
Eric Kosel
Old 03-08-2009, 11:29 PM
Us'ta have a 96' Tahoe. All it needed was a Brake controller and a weight dist. hitch. It towed a YJ on a trailer all over the Northwest and Southwest. Kinda slow going at times.
The weight dist. hitch completly does away with the need for airbags or overloads. Why make the rear able to carry more weight then tighten up the weight dist hitch and remove the weight??
The only problem this Tahoe ever had (sold at 215K miles) that came from towing was it went thru an outer axle bearing (proabaly the high mileage did it in).
If I were to do anything over again it would be to beef the rear axle by replacing the 10 bolt with a 12 or 14 bolt. That's all you would maybe need to do. We put 100k hard miles on the rig. Darn good tow rig for what we spent on it.
Old 03-09-2009, 01:33 PM
The only problem with a weight dist. hitch is I don't have my own trailer... I borrow them for the time being. I also found a 3/4ton Chev that was wrecked. I can get it for $400 and it looks like all the running gear is good. Something to think about.
Chad - KE7VSA
