Go Back   Pacific Northwest Four Wheel Drive Association > Around the Camp Fire > Questions Concerns Comments
Questions Concerns Comments belong here
Old 01-09-2009, 07:08 PM
Duck Dodgers's Avatar
Duck Dodgers Duck Dodgers is offline
Aimless Wanderer
Location: Somewhere between the Port of Indecision and South of Disorder
nope....
Is there a group setting? I noticed Ceg and I have different names of the type of user. Could that have something to do with it. I messed vBulletin years ago and it can be a bit finicky if I recall.
NW-Wheelers is a vBulletin board and I can see the PM option in "Edit Options" there. Gotta be some obscure little box some where that needs to be check.
Originally Posted by MarkoPo View Post
We all know in the beginning God created the earth and the Heavens. On the second day God created man and Jeep. Man had too much fun so God created woman. Man hasn't had near as much fun since.
Old 01-09-2009, 07:22 PM
Aimless Wanderer
Try this....
For permission changes that affect all of the forums, you can edit the actual user group (instead of using custom forum settings). Click on the Modify link (under the User Groups and Permissions section of the control panel. The following screen will appear:
From here, you can choose to Edit the user group options or List All Users assigned to the group. If you've created a custom user group (i.e. a group that isn't one of the core seven listed above) you can delete the group from this screen.
If you click on the Edit link next to a user group, you'll be presented with the following form:
The options listed on this form affect all users that are assigned to the selected user groups. Let's take a look at each of the options in more detail:
  • User Status - if you wish all users within this group to have a certain user title, fill in this field.
  • Can view board - select yes for this option if you would like all users in this group to have access to the bulletin board. If you select no, the users will receive the standard vBulletin log in screen.
  • Can view members info - select yes to allow the user to view other users' profiles.
  • Can view others' threads - select yes to allow the user to view threads posted by all other users.
  • Can search - select yes to allow the user to use the vBulletin search engine (to find relevant threads and posts).
  • Can use 'email to friend' feature - select yes to allow the user to forward threads to friends via email.
  • Can modify profile - select yes to allow the user to edit his/her's profile via the online user control panel.
  • Can post new threads - select yes to allow the user to post new threads.
  • Can reply to own threads - select yes to allow the user to reply to threads that he/she started.
  • Can reply to other's threads - select yes to allow the user to reply to threads started by other users.
  • Can Rate threads if thread rating is enabled in the forum? - each thread can be rated from 1-5 (where 5 is the best). This feature can be turned on/off on a forum-by-forum basis. If you would like to allow the users assigned to this user group to be able to rate threads on forums where the feature is enabled, select yes.
  • Can post attachments - select yes to allow this user to post file attachments.
  • Can edit own posts - select yes to allow the user to edit his/her own posts/messages.
  • Can delete own posts - select yes to allow the user to delete his/her own posts/messages.
  • Can move own threads to other forums - select yes to allow the user to move threads that he/she started into another forum.
  • Can open / close own threads - select yes to allow the user to open/close threads that he/she started.
  • Can delete own threads by deleting the first post - select yes to allow user to delete an entire thread that he/she started by deleting the first (original) post/message.
  • Can post polls - select yes to allow the user to post polls.
  • Can vote on polls - select yes to allow the user to vote on a poll (posted by any user).
  • Can use Private Messaging - select yes to allow the user to send/receive private messages to/from other users.
  • Can Use Message Tracking? - message tracking is a feature in the private messaging system that allows a user to request read receipts... i.e. a user can find out whether or not a user read his/her private message. To enable this feature for all users assigned to the user group, select yes.
  • Can Deny Private Message Read Receipt Request? - to counteract the message tracking feature, select yes to allow users to prevent the software from sending back a read receipt.
  • Maximum Buddies to Send PMs at a time - you can set a limit to the number of private messages that can be sent at once here.
  • Maximum PMs to Forward at a time - you can set a limit to the number of private messages that can be forwarded at once here.
  • Can post Public events on Calendar - select yes to allow the user to post an event on the calendar that can be viewed by all users.
  • Can edit other's Public events on Calendar - select yes to allow the user to edit other users' public events.
  • Is Super Moderator - select yes to allow the user to moderate all forums.
  • Can access control panel - select yes to allow the user access to the vBulletin admin control panel.
Please remember that these options will affect the global permissions of all users assigned to this user group. If you wish to change the settings for a user group for a certain forum (i.e. to set up a private area for moderators and administrators), you can set up a custom setting for each forum affected.
Old 01-09-2009, 08:09 PM
JeepNirvana's Avatar
JeepNirvana JeepNirvana is offline
<----Busy Wild
Originally Posted by Art Waugh View Post
I take it the visitor messengering is the PM function? Only thing close in my edit options.
You should no longer be receiving visitor messaging.
Dan Rheaume
RAY-OME
Outdoor 4x4's
Cascade4x4s
Webteam member
Forum Admin
Old 01-09-2009, 08:18 PM
<----Busy Wild
Originally Posted by Duck Dodgers View Post
nope....
I'm sorry Ducky and thank you for the assistance. I can assure you you are enabled in the correct user group. For some reason the first several folks that signed up you dirk and Ceg are having issues. We will get it corrected soon.
Your pizza may not be called in turn some pizzas take longer to burn.
saw that at Pietros Pizza as a kid..
Dan Rheaume
RAY-OME
Outdoor 4x4's
Cascade4x4s
Webteam member
Forum Admin
Old 01-09-2009, 09:24 PM
Aimless Wanderer
LOL.... no worries. I know how much work is envolved just setting these durn things up to work with the basics.
Old 01-10-2009, 06:29 AM
Duck Dodgers I found your PM's turned off in your profile, you might have them now????
When I get back from the Wa State Meeting today I will dedicate some Hours to the board and get cought up.
Old 01-10-2009, 10:50 AM
Aimless Wanderer
OK so I got a PM. But I cannot reply or create a new PM, all UI cab do is delete.
Old 01-10-2009, 04:49 PM
I also am not able to pm someone. I have clicked on user Cp and do not have a way to enable this feature.
Old 01-10-2009, 06:47 PM
<----Busy Wild
You got a PM because it was sent by an Admin...me.
Edward and I have a brain storm session tomorrow. Sunday. He's the brains, I'm the storm.
We'll get it fixed, it has to be something to do with the member settings.
All of you are able to see the super secret PNW members forum correct?
Dan Rheaume
RAY-OME
Outdoor 4x4's
Cascade4x4s
Webteam member
Forum Admin
Old 01-10-2009, 06:48 PM
<----Busy Wild
I'm sorry Merrick, we will get it fixed tomorrow, when it is working properly you will have the ability to turn your pms on and off yourself.
edit: that's kinda funny..if you know what I mean?
Dan Rheaume
RAY-OME
Outdoor 4x4's
Cascade4x4s
Webteam member
Forum Admin
