Go Back   Pacific Northwest Four Wheel Drive Association > Tool Bag > Garage > RV Tech
RV Tech Big or Small
Old 07-26-2009, 10:04 PM
Default Cellphone Tech
This could have gone in a few areas on the board. Just bought a Wilson Electronics cellphone booster. For those on the West side I had zero dead zones between Tacoma and Elbe. Confirmed with friend all known Hwy 7 dead zones. Minimum service on Hwy 7 was 2 bars with the booster. At the Elbe parking lot I had 3 bars on my Verizon cell. Moved the setup to my Jeep. 2 solid bars with occasional 3 bars. I had service 1/3 of the way into the Busywild. Made various calls using Parrot Visor Bluetooth device. Going to test next weekend at Evans Creek. I went with this particular model due to Wilson tech support suggestion. Needed something to work in the tow rig and Jeep.
http://www.beachaudio.com/Wilson/811214-p-132083.html
Old 07-27-2009, 02:58 PM
Nichol's Avatar
Nichol Nichol is offline
rollin
Gadget guy! Now, if it could only work at Jim Sprick park.
Nichol Phillips
Cascade 4x4's Tacoma
El Dorado Dust Devils
Old 07-27-2009, 03:35 PM
A Wilson antenna with no booster is known to work from the Park. I am looking into such a purchase to install at my Nile home. Others have them and report that it indeed does work. USCellaur has been rumored for years to be about to bring cell service to the area.
Old 07-27-2009, 03:56 PM
Drive up on the ridge and US Cellular does work.
I have use mine on 1702 below 1720.
Old 07-27-2009, 04:28 PM
If you stand next to a certain rock in the park and hold your neck just right Verizion works from the park.
Old 07-27-2009, 04:38 PM
You tell people that just to see if they would do it uh?
It was kind of like that at Wiley City Rodeo. You had to put your phone over a 55 gallon drum in the parking area if you had AT&T to get a call out.
Old 07-27-2009, 09:11 PM
Often times the key fob to my truck will not work as I am walking away from the truck. If I hold the fob to my chin the truck door will lock/unlock. Must be that my empty head reflects the signal.
Old 07-27-2009, 09:15 PM
Now that is different.
Old 07-27-2009, 09:34 PM
I saw Logan's wife make a call from the park while standing on a tool box on the trailer. The Wilson combo should give an easy two bars.
Merrick,
Does your new place have high speed internet? One of our members has Verizon service. They had between zero service and one bar in the house. They bought a Verizon repeater that connects to their landline high speed internet. They now have full 4 bars in the house. Also, Wilson sells in home setups that can repeat service upto 6 separate phones in 1-2 rooms.
Old 07-27-2009, 11:36 PM
Merrick,
Only available via satellite. May change if cell service comes to the area. I have phone service (landline). Will go with satellite when we need to unless things change.
