Go Back   Pacific Northwest Four Wheel Drive Association > Tool Bag > Vendors
Vendors Links and forums
Old 08-08-2009, 09:58 PM
4WheelingPlus.com 4WheelingPlus.com is offline
Member since 1996
Default Heavy Duty 8,500 LB Off Road Winch - Rugged Ridge
Rugged Ridge Heavy Duty 8,500 LB Winch - Features/Specifications:
- Durable 5.5 HP Series Wound motor for long life and extra pulling power
- Tough 3 stage planetary gear box with a 172.8:1 gear ratio delivering power and reliability
- Includes 94' of 5/16" diameter wire rope and latched hook
- Automatic load holding brake system (in the drum brake system)
- Exclusive light mount roller fairlead included! Allows for easy no-drill mounting of up to 2 off road lights! (Not included)
- Tough stainless hardware is used on the body of the winch to eliminate rust
- Each winch includes a durable 12' all weather cable remote control
- Solenoid box can be mounted in multiple positions (over roller or over motor) as well as different angles to accommodate most winch bumpers including the Rugged Ridge XHD Bumper System!
- Limited 2 year warranty against manufacturing defects (1 year on electrical)
Rugged Ridge 8,500LB Line Speed and AMP Draw-First Layer:
Order them here: http://store.4wheelingplus.com/prodd...rod=15100%2E01
