Go Back   Pacific Northwest Four Wheel Drive Association > Rigs > Jeeps > TJ's
TJ's Coiled up
Old 01-07-2009, 07:07 PM
Jon KB Jon KB is offline
Default Jon K-B's Rig
Evans Creek 2006
1997 TJ new to me stock
Reiter pit 2007
4" lift 1" body ,33" tires, Modified front bumper, added Winch, home built On-Board Air,
Liberty 2008
Added home built Rocker Guards/Sliders,Tom Woods Axle and super shorty SYE kit, Home built tire swing carrier
Jon K-B
Cascade 4X4's
Jon KB
Too many hobbies not enough time or dollars
97 TJ Green, 33's, 4.0L, NV3550, 4" SL, 1" BL
02 TJ Yellow 32's, 4.0L, auto, 2" SL, 1" BL
99 VZ800 Red
99 GSX-R600 Yellow
83 VF750S Red
Last edited by Jon KB; 01-07-2009 at 09:42 PM. Reason: Last Image loaded incorrectly
Old 01-07-2009, 09:30 PM
Thumbs up
Nice mods so far.
Old 01-12-2009, 11:17 AM
wood's Avatar
wood wood is offline
Pimp of the woods
Good looking jeep, what are you running for on board air? Is it a A/C mod?
Strange things are afoot at the Circle K
Old 01-12-2009, 03:54 PM
Default Oba
Yes it's a A/C mod.
I'm using a York A/C unit from a Volvo, all parts were self-fabbed or scrounged with the exception of the serpentine belt pulley wheel and the oil/air separator.
Works very well although I will add a under-hood manual throttle lock to allow increase the idle while airing up. Currently it takes 1 -2 minutes per tire.
I have also collected sime low volume air-tools that can run off of it.
Jon KB
99 VZ800 Red
99 GSX-R600 Yellow
83 VF750S Red
Old 03-29-2011, 11:00 PM
ReedJeep's Avatar
ReedJeep ReedJeep is offline
Hey Jon, nice jeep. I am currently working on a self York 210 a/c mod myself for an 05 4.0 w a/c.
I figured I could fab the bracket with a little welding time. However I am almost half way to spending as much as I should have to buy the dumb expensive Kilby system.
Could you give me some incite on how you made your bracket. I have the plate and holes down pretty good. I think it is the positioning of the alt bracket on the bottom. I am not leaving either enough room for the idle tension or something because I cant get the belt to clear. Pix would be great or some helpful hints.
Thanks for any help or advice.
GO PREPARED
